Massey Fergerson 230 Power Steering Help
Phillip
03-16-2003 19:23:16
Having problems with the power steering on a high hour 230. Am mechanically inclined but don't know anything about power steering except the very basics. When I check the fluid when the pump is operating it is very frothy as if air is in it. The steering works fine when you first start up in the morning after an overnight. As you operate it the steering becomes "hard" to turn. Sometimes it will turn very easy one way and very hard the other way. Also it seems that everytime I remove the fill plug it overflows even though no fluid has been added. I have tried steering hard right and left several times to bleed air but it did not help. Can someone give me a clue or two as to what to look for or what to check. Also it seems that you have to turn the steering wheel an excessive amount before there is any action on the steering hydraulic cylinder. Removed the fill plug one time and it pulled a vaccumm. Any help appreciated thanks in advance.
BMartin
03-20-2003 11:16:49
 Re: Massey Fergerson 230 Power Steering Help in reply to Phillip , 03-16-2003 19:23:16
Phillip,
Dean Austin has a very good web site and if it's not on Dean's web site, you can Email him. He is a very helpful man. [email protected]
