MF 230 Vapor Lock
Wayne Wiseman
03-16-2003 18:26:24
My nephew just inherited a 1978 Massie Ferguson 230 gas. When the tractor gets at operating temperature the engine stops because of vapor locking. When tractor cools, then tractor will run for awhile longer. Contacted the local MF dealership and they said it was a common problem with the 230 and the only thing could be done is to trade the tractor for a newer model. Any help it solving the problem would be appreciated.
Thanks Wayne
Wayne Wiseman
03-17-2003 16:45:16
 Re: MF 230 Vapor Lock in reply to Wayne Wiseman, 03-16-2003 18:26:24
Thanks to Bill and Robert for your help. This will give me a place to start.
Wayne
Bill
03-17-2003 09:52:54
I knew a fellow who had an old Ford Bronco, the original boxey type and it had a problem with vapor locking. I think, if I recall correctly, he took a finned power steering tube and connected it to his gas line, in place of the original. This allowed the heat to dissipate from the fuel line and solved the problem.
Bill
bob
03-17-2003 21:46:16
 Re: Re: MF 230 Vapor Lock in reply to Bill, 03-17-2003 09:52:54
An old trick is to put wooden clothespins on the fuel line. This also disipates heat. Just clamp 2 or 3 of them onto fuel line, as close as you can get to the carb.
Robert in Md.
03-16-2003 19:03:16
My dad had a MF 65 that did that. It had a exhaust that went down under the tractor. I made a adaptor and run the exhaust straight out about 6 inches and put a pipe el on and ran it up. This got the heat away fron the carb and solved the problem. Hope this helps.
