Piston Ring Overhaul
MF 40 Ind
Greg Reed
03-16-2003 18:16:26
OK, the general concensus seems to be that I have the not unusual problem of worn piston rings in the Perkins diesel.
Anyone know if the oil pan on the MF 40 Industrial can be removed without splitting the tractor? The oil pan looks like a structural memeber, tieing the transmission to the front axle. Even so, it would save a lot of time if the transmission could be supported and the oil pan removed in situ. I guess the engine block is still bolted to the flywheel housing, which is also bolted to the transmission? It looks possible, but does anyone have any advice on this?
