T035 shifter lockup
Mark Indiana
03-15-2003 14:40:12
My TO35 transmission shift locked in reverse. The local Massey repair guy advised that I remove the tranny oil filler cap and slide the gears on the shift rails. Got the low gear to slide forward...but the main shift lever still will not budge. No evidence of lost/broken spring on the shift lever. I've tried rocking the tractor while attempting to leverage the gears on the low shift rail...won't move. Planetary shifter moves fine. Tractor will now move forward, but only in low gear. Anyone have experience with this?
Thanks
MSW
nigel from tasie
03-21-2003 20:55:13
 Re: T035 shifter lockup in reply to Mark Indiana, 03-15-2003 14:40:12
If you remove gearlever boot, tap pin securing lever out & lift gear lever, you can then align shift rails with screwdriver & refit lever.
