MF-135
wheel popping
tmcommon
02-09-2000 09:18:42
I recently bought a '65 MF-135, gas - 38hp.
There is an intermitant popping sound coming from the RH rear wheel when making a left turn. After the pop, the tractor seems to make the turn better. This doesn't happen constantly, but occurs more often in high. Any ideas on the cause?
Also, considering buying a 6' offset disk. Any thoughts about whether this tractor has enough power for it?
Thanks, tmac
Gerald J.
02-09-2000 11:16:21
 Re: MF-135 - wheel popping in reply to tmcommon, 02-09-2000 09:18:42
The 6 foot offset I made from a 12 foot Oliver disk by mounting two gangs in the middle pulls just as hard as 2-16s case plow. Both are practical behind my MF-135, though not at the same time. I have to lift this heavy disk with the wheels to keep the hubs above the clods. Otherwise the hubs of the disks would be underground and make it a lot harder to pull.
Gerald J.
Old Man
02-09-2000 10:40:16
If you have dif lock, it might be engaged slightly. Check the foot pedal. It might have a week spring. Also, check your wheel bolts. If two are loose, the wheel will pop.
