Massey Harris model 22 (1953)
James Cayer
03-14-2003 18:31:12
I'd like to know how to remove the cover below the gear shifter. I've unbolted it and for a reason unknow to me i can't lift it off. Is there any particuler way of lifting it off, or is it attached by something else. Please send back a soon as possible on any information you might have regarding this. Thank you in advance.
herman
03-21-2003 08:52:35
 Re: Massey Harris model 22 (1953) in reply to James Cayer, 03-14-2003 18:31:12
James,
If we are talking about the same thing (Where the gearshift lever goes into the tranny?), there is no trick to it. If it hasn't been removed in a while, the gasket is probably holding it. Occassionally, the gearshift lever will cause a problem, but if it is free, shouldn't be a problem either.
Little prying with a screwdriver ought to pop it loose. Good luck
