Too Much Oil Pressure
Donnie
03-13-2003 11:57:30
I have a TO35 (engine Z134 gas) that had the engine rebuilt recently. After two hours running, It blows oil out the rear seal, distributor mount and excessively out the oil breather hose. When I loosen the oil cap, all the leaks stop. The oil breather hose is not clogged. What could it be? Will it hurt to run the tractor with the oil cap loose. It is not burning any oil either.
Help Please!!
Bob
03-14-2003 20:40:02
 Re: Too Much Oil Pressure in reply to Donnie, 03-13-2003 11:57:30
How is your crankcase vented? Does it have a tube dropping down from the side cover on the engine, or does your engine require a vented oil filler cap? The possiblities are... excessive blowby, or an improper fill cap, or clogged crankcase breather.
CH
03-13-2003 16:03:20
Not too much oil pressure, too much crankcase pressure. Could be a ring or valve problem.
