Starter Wiring?
Colin
03-12-2003 05:39:24
My father and I were troubleshooting a no-start problem and found it was a bad positive lead. In the process, however, we disconnected all the wires from the cellanoid (accept the yellow) and are uncertain how they go back on. The cellanoid has 2 terminals on it (the yellow wire has a separate conection from these), and it seems from the wiring diagram that the positive lead, the alternator, and the brown wire (which meets the yellow eventually at the key ignition, i think) are all connected at the 'top' terminal of the cellanoid. This leaves the 'bottom' terminal with no wires, but i was sure that there was at least one wire on it (and if not, why is it there??). I'm pretty sure the positive lead goes on the 'top' terminal because the circuit is closed only when the key is turned (touching the pos lead to the 'bottom' terminal of the cellanoid closes the circuit regardless of key position!!). Can someone shed some light on how this wiring should be and why? Thank you!
ALAN
03-12-2003 19:34:50
 Re: Starter Wiring? in reply to Colin, 03-12-2003 05:39:24
Your description was very detailed, but it may be helpful to know the model # so we can look in our service manuals (sometimes the feeble-minded need pictures). If you can send a little more info it would be helpful... However, one thing that is almost always true is the wire from the starter is all by itself. Usually the other wires all pile up on the other terminal. Let us know what model it is & we'll all give it a whirl - ALAN
Colin
03-13-2003 05:07:01
 Re: Re: Starter Wiring? in reply to ALAN, 03-12-2003 19:34:50
It's a MF 231 diesel. Sorry, I meant to give that!!
