Hydrulics
paul luft
03-08-2003 17:35:06
on ford 9n with 3pt plow in up position,when put clutch down, the plow drops because hyd. becomes desingaged. is this true on MF35 ornewer models of ford? thx paul
Oldfarmboy Jim
03-10-2003 20:10:34
 Re: hydrulics in reply to paul luft, 03-08-2003 17:35:06
My MF35 has a two stage clutch, so I can shift gears without disengaging the pto or having the 3 point hitch fall down. With my 841 and 2000 Ford the 3 pt stays up even when the clutch pedal is all the way to the foot rest. Hope that answers your question. Jim
marlowe
03-08-2003 17:43:09
when you push clutch in the hyd. pump stops but your plow will stay up but after time it will bleed down but it will not drop fast if it dose you have a problem
