MF 165
Jake
03-06-2003 05:43:44
I have 67-68 165 and the hyd on the loader are very slow and will not lift much weight.How much weight should it be able to lift?
Could the hyd.pump be bad?
Any suggestions would be great
Thanks
Craig
03-08-2003 13:22:25
 Re: MF 165 in reply to Jake, 03-06-2003 05:43:44
I would first check to see how much pressure is coming from the pump. It is possible that a valve is not working correctly allowing oil to bypass or a cylinder's packing is blown out causing a loss in pressure. How much weight it would lift would depend on the loader, the size of the cylinders etc. Some loaders have bigger cylinders that will work slower, but pick more weight.
Craig
03-08-2003 12:56:11
