MF 250 Transmission Hey Dean or anyone else----Thanks
tortmort
03-03-2003 20:32:35
I just got a MF 250 1985? The transmission is different from what is listed in the Operator's Manual in that it has High/Low shifter and a gear shifter for the gears but it also has a hand lever to the side of the hood for shifting forward and reverse. Most of the time the fwd/rev shifter works fine but it will often not shift fwd/rev with out gringing the gears. Will this tear up the transmission? What is the problem/fix. I like the set-up it is very handy. Is it an aftermarket shifter? Thanks
bob harned
07-08-2004 14:05:26
 Re: MF 250 Transmission Hey Dean or anyone else-- in reply to tortmort, 03-03-2003 20:32:35
It is called shuttle shift and must be a factory option. Ny 250 ha the same setup. It is great, but mine also grinds into gear. I have had it 6 years and so far so good. Tough tractor!
