6 or 12 Volt system ??
Harvey
02-28-2003 10:37:10
I have a Pony (new to me), the manuel says it has a 6 volt system, but there is an alternator on it, my neighbour says it must have been converted to a 12 volt system. We're not sure what this conversion system would even look like. What do I have 6 or 12.
Tks
Harvey
Lee
03-01-2003 06:31:06
 Re: 6 or 12 Volt system ?? in reply to Harvey, 02-28-2003 10:37:10
You can have a 6 volt alternator. You can buy a 6 volt alternator in JC Whitney, but only with a postive ground. Best to check your battery for the 3 or 6 cells.
Lee
03-01-2003 06:32:14
 Re: Re: 6 or 12 Volt system ?? in reply to Lee, 03-01-2003 06:31:06
My mistake, I meant negative ground.
Alberta Mike
02-28-2003 21:18:55
Well if it's running an alternator then you've got a 12 volt negative ground (as in automotive) conversion. The Pony's were originally 6 volt positive ground system. The original starter can handle short bursts (not sustained) of 12 volts easily since they were built pretty heavy. Check in the articles sections here in the left margin ... there are lots of articles in there on 12 volt alternator conversions and methods.
