Massey harris 33 grill
Regier
02-28-2003 04:32:46
I recently bought a 1953 massey harrys 33 and it has a hole in the top of the grill that does not lead to anything, the rad sticks threw the hood and it just has this hole infront of it that is just there. Is this posibly not the correct grill for a 33
REGIER
02-28-2003 06:15:11
 Re: massey harris 33 grill in reply to Regier, 02-28-2003 04:32:46
That will be it! the tractor has no hydraulics. thanks for the info. (I must say the hole looks odd and just not right, with it leading to nothing.)
marlowe
02-28-2003 04:59:36
mike is right hyd.tank fill hole if you have hyd.
Alberta Mike
02-28-2003 04:35:56
How big is the hole? Does your tractor have factory hydraulics? It might be the location for the fill neck on the hydraulic tank in front of the rad. Some other Masseys had the fill neck and cap there.
poorerbut
02-28-2003 12:00:09
 Re: Re: massey harris 33 grill in reply to Alberta Mike, 02-28-2003 04:35:56
A long time ago, we had a gas & a diesel 33.
Both had hydralics . Seems to me that the gas
had the fill neck for the reservoir and a dip
stick coming above the grill, but the diesel had
a lower reservoir and there was a sheet metal
dust cap on the grill that you had to pry off
with a screwdriver to check the hydralic oil.
My memory ain't what it used to be-that was 30
years ago, and it weren't real good then.
pb
Alberta Mike
02-28-2003 12:13:53
 Re: Re: Re: massey harris 33 grill in reply to poorerbut, 02-28-2003 12:00:09
The 333's had a little sheet metal door for the hydraulic fill pipe access.Maybe you guys had a 333 ?
poorerbut
02-28-2003 12:29:03
 Re: Re: Re: Re: massey harris 33 grill in reply to Alberta Mike, 02-28-2003 12:13:53
Nope- Just went to dig up the old pictures
outa the attic.(ex) pappy-in-law still has the
gas and I traded the diesel on the Super 88.
Both 33's- 333's had the fancy sheet metal at
your knees-cylinder pinched you and hit the
seat everytime you raised and lowered the plow
on ours. That cover was like an flywheel inspection hole cover.
btw-did you get my e-mail?
pb
