Bought a MF 65 LP, Should I change it to GAS ???
Jerry C
02-25-2003 19:47:01
After reading different posts about propane, beginning to wonder if I should look into converting it to gas. How much trouble is this? i know you need gas tank, hood,etc. What about fuel pump and so forth Thanks Jerry C
I really like the tractor though !!!!!
Gary in Geneva
02-27-2003 03:11:33
 Re: Bought a MF 65 LP, Should I change it to GAS ??? in reply to Jerry C, 02-25-2003 19:47:01
Propane is good stuff. It burns cleaner, engines last longer, costs less per gallon, doesn�t go bad like gasoline, etc. I have been driving vehicles burning propane for over 20 years.
Jerry C Thanks Guys
02-27-2003 10:04:23
 Re: Re: Bought a MF 65 LP, Should I change it to GAS ??? in reply to Gary in Geneva, 02-27-2003 03:11:33
Thanks for the comments, gonna leave LP, Also got email from Big Dean, same advice....appreciate it Jerry C
Jerry c
02-26-2003 09:58:33
Thanks for the comments , I don't really want to convert, may be a little hassle to refil, but that's OK Jerry C
Tom
02-26-2003 09:40:33
Leave it alone, if all is working
Jeff
02-26-2003 06:41:15
There may be a different head/piston combination for it to run on gas too!
Gordon-(TN)
02-26-2003 01:10:52
I would leave it like it is, it has higher compresion head and most likley would not preform as well on the lower octane gas + the propane burnes cleaner, propane octane is about 105 compared to 87 gas this is a good question for Big Dean hope this helps.
Gordon-(TN)
