WHATSIT?
Jim
02-22-2003 15:37:02
I bought a tractor today, i cant find a tag, but it is a 20 i think. it looks like a 22 with a 20 style grill. any ideas? any characteristics i might look for? and is a 20 worth fixing? thanks in advance!
Jim--heres the #'s
02-23-2003 08:08:21
 Re: WHATSIT? in reply to Jim, 02-22-2003 15:37:02
the only #'s i found were where you told me they would be, 400537. right in front of the pto shift lever, just behind the shift platform. thanks
Alberta Mike
02-23-2003 12:39:18
 Re: Re: WHATSIT? in reply to Jim--heres the #'s, 02-23-2003 08:08:21
Looks like you've got the 537th rowcrop model 81 that was made. The first year of production (1941 which is your year) started with 400001 and ended with 403167 for the rowcrops. Wide fronts started that same year too. Production ended in 1946 for both versions and the 20's and 22's started that same year (1946). The model 82's were made at the same time as the 81's and I'm not sure how those two models differed from each other, that might be an interesting question to ask, they sure looked alike as did the 20's and 22's. I'm just getting this stuff from a book here, I don't really know it (it'll be forgotten by suppertime).
Jim
02-24-2003 11:06:08
 Re: Re: Re: WHATSIT? in reply to Alberta Mike, 02-23-2003 12:39:18
THANKS TO ALL ON THIS ONE, ESPECIALLY YOU ALBERTA MIKE!!!
Alberta Mike
02-22-2003 16:23:36
Sounds like you are pretty sure it is a Massey Harris so let's assume that it is. Go to the top of the transmission/differential housing. Between the cast iron shifting platform (that has the gearshift lever coming out of it) and the steel plate that covers the rear end gears will be the serial number. Between these two covers on the upper machined surface of that housing (on the left side near where the clutch pedal is) is a number which is hand-stamped into that machined surface. It won't be easy to find, start wire-brushing and scraping the paint away but it will be there. Post it here and someone will ID it for you and tell you the model and year too.
Jim
02-23-2003 10:20:15
 Re: Re: WHATSIT? in reply to Alberta Mike, 02-22-2003 16:23:36
i think i have it figured out. i was looking at the pictures of a mh 81 and according to one comments, the 32 inch tires were only on two tractors, the 81 mh and the john deere H. and the serial # would match with an 81. am i halfway close mike? hehehe. anyway, is an 81 worth fixing? anybody have any tips? thanks
Jim from Ill
02-23-2003 05:47:32
Man---is Alberta Mike good, or what!
Jerry Aspinall
02-23-2003 10:04:16
 Re: Re: Re: WHATSIT? in reply to Jim from Ill, 02-23-2003 05:47:32
Alberta Mike is one of the best in knowledge of Massey Harris tractors. I know him personally and have stayed at his home when in Alberta. I will visit him in Aug. when I go to Canada to pick up a M.H. Pony that I bought Near his home. He and his wife are 1st.rate. Jerry
Alberta Mike
02-23-2003 12:30:07
 Re: Re: Re: Re: WHATSIT? in reply to Jerry Aspinall, 02-23-2003 10:04:16
Jerry, you're making me blush. Yes, Jerry has been up here twice, the first time last summer with his wife and we saw some neat stuff in and around the area. He has sooooo much of that American money that it just falls out of his pockets as he walks around on the street !!! And he even spends some of it on old iron in Alberta !!
