TO35 oil pressure
Doug
03-08-1999 07:35:54
We just got our restored TO35 running Friday. It seems to run fine but the oil pressure is only around 23-25 lbs at all speeds. We have 10w-30 oil in it now. We put new bearings in it and had the crank worked on so the clearances should be okay. Also we put a new spring in the oil pump and checked the pump gears for endplay. Is this enough pressure for this engine?
