MF135 that will not keep running!
Jack M, UK
02-12-2003 09:51:29
I have an MF 135 that I have been trying to restore. I had the engine overhauled and it ran fine, I had it running for about 45min to worm it up so I could tighten the head down.
I left the tractor for a few weeks, and now it will only run for a minute or so! Someone said that it may be because of air in the fuel system, and someone else said that it may be the lift pump failing. I did not replace the fuel filters because they were 1/2 year old and it doesn't get used a lot.
Hope this info helps,
Thanks for any reply, greatly appreciated.
Jack M, UK
smokey
02-13-2003 02:19:47
 Re: MF135 that will not keep running! in reply to Jack M, UK, 02-12-2003 09:51:29
Also check for blockages - the conical mesh filter in the fuel tank above the fuel tap - you may need to remove the tap. - and the mesh filter above the lift pump bowl - its hard to see but it should be there. I have a diesel and its tank was burnt in a fire. I needed to clean these filters several times before it was OK. apart from that listen to Big Dean.
Big Dean
02-12-2003 11:41:47
Jack it could very well be the lift pump but I would change the fuel filters first it only takes a little water in those filters to stop the fuel from flowing through them.
Jack M, UK
02-13-2003 11:01:03
 Re: Re: MF135 that will not keep running! in reply to Big Dean , 02-12-2003 11:41:47
Thanks for the quick response, I will get to it at the weekend when i'm free from college!
Another thing, I take it that all of the body of the tractor should be greay, and the muguards and bonnet is red?
Thanks alot, I think this site works great!
Jack M, UK
