MF tricycle front end
fergusonfan
02-11-2003 06:01:15
Has anyone ever had any good or bad experiences with a tricycle front on a MF 165 or 65? Just wondered if it would weigh less than the wide front end on our 165 now. Thanks.
Terry Clubb
02-13-2003 15:02:58
 Re: MF tricycle front end in reply to fergusonfan, 02-11-2003 06:01:15
fergusonfan we have had tricycle front ends on mf 50s to 1130s personaly prefer over wide front in our operations because you can turn in a shorter distance especisally when cultivating.disadvantges are loader operation and in muddy field coditions as they will plug up . they are guessing half of yhe weight of wide fronts you didn,t say if it was a single wheel or dual wheel. any questions call 502 222 9055 or email good luck Terry Clubb
fergusonfan
02-18-2003 03:39:24
 Re: Re: MF tricycle front end in reply to Terry Clubb, 02-13-2003 15:02:58
thanks for the response. I figured they weighed less than the wide fronts. I had the privilege to drive a 65 diesel with the dual wheel tricycle front once...I was amazed that I could turn it with one finger!! I was just thinking of maybe tracking one down to use on our 165 at the local tractor pulls. Right now, our 165 weighs around 4650 empty. I'd like to get it down a bit so we have some weight to move around for the 5000 lb. class we pull in. Thanks.
