The Massey-Harris Model 55G ----- ----- ----- ----- ----- ----- ----- ----- ----- ----- ----- ----- ----- -- Capacity: Four to five 14 inch plows Performance (Nebraska test no 455) 66.91 hp max. belt; 57.55 hp max. drawbar; max. pull 6377 lbs at 2.63 mph (corrected to sea level basis) 68.20 hp max. belt; 60.45 hp max. drawbar. Engine: Own Model J382, O-head, 4 cylinders vertical, removable cylinder sleeves. 4 1/2" X 6" -1350 rated RPM, 1510 to 1520 max. no-load rpm, displacement 382 cu. in. Service Data: Champion 18 mm spark plugs, 8 Comm., M-H no. 1503288M91 or Auto-Lite BT8 M-H no. 1004753M91; Four rings per piston, 3 compression 1/8", 1 oil 1/4". Accessories: Auto-Lite Model GHD-6001R generator standard equipment; Exide Model XQ-23 battery standard equipment; Zenith Model 62AJ10 model carburetor, size 1 1/4"; own governor; Guide lamps; Donaldson Model A-722 air cleaner; Purolator Model P-913 oil filter, cartridge no. 1003878M11 Borg & Beck 2-piece clutch, part no. 764719M91; Modine radiator core, capacity 7 gallons; Harrison thermostat standard equipment; Radiator shutter optional equipment; fuel tank capacity 27 1/2 gals.; French and Hecht front and rear wheels; Timken front wheel and rear axle bearings; Timken and Hyatt transmission bearings. Tires: Standard-14x34 rear; 7.50x18 front. Oversize 15x34 rear. Brakes: Two brakes located on brake shaft, foot operated either individually or simultaneously by interlocking. Speeds: Standard tires- 2.96, 4.22, 5.22, and 12.07 mph; reverse 2.54 mph. Oversize tires- 3.08, 4.39, 5.42, and 12.53 mph; reverse 2.64 mph. Shipping Weight: Std. - 7150 lbs.; Dimensions: Wheelbase 88 1/2"; height overall 83 1/4"; width overall 72 1/2"; rear wheel tread 57 5/16"; Turning Radius 12'. Power Take-Off (Optional) 1 3/8" spline shaft, 521 RPM; spline end 36 3/8" above ground, 1 1/16" left of centre line of tractor and 12 1/4" ahead of hitch point. Pulley: (Standard) 16 x 8", 730 rated rpm, 917 to 822 governed no-load rpm; belt speed 3058 fpm. Lubrication: Crankcase capacity 10 quarts; transmission case capacity 17 gals. Hydraulic Lift (Optional): Webster pump- Model 3HC1-A; 10 gpm delivery at 1070 psi operating pressure; reservoir oil capacity 14 qts. Double acting cylinder; 3 1/2" inside diameter; 8" piston stroke; both push and pull variable stroke control
