Loaded vs empty tires MR135 hydraulic lift capacity
Will
02-09-2003 09:15:52
I ran out of wood and bought a load yesterday and used my MF135 diesel w/boom pole to get the wood off my pickup, this is a standard pallet with wood
stacked 4 feet high wired down. The front end of the tractor kept coming up when lifting the pallet (with chains to the boom) but the 3pt was able to lift the wood enough to drag it off the truck.
How much can the hyrdaulics on this tractor lift? I couldn't find an answer in the owners manual.
I just had the calcium chloride pumped out two weeks ago and retubed all four tires. The salt had seeped out and ate up some of the rear rims. I'm considering puting RV antifreeze back in, is this something I can do myself? I paid $270 to a guy to pump out the calcium and put new tubes on and I really don't want to spend that sort of money again. Would wheel weights be cheaper? Thanks
fergusonfan
02-11-2003 06:08:34
 Re: Loaded vs empty tires MR135 hydraulic lift capacity in reply to Will, 02-09-2003 09:15:52
I'd consider investing in a set of front suitcase weights for the tractor. They can usually be picked up for $15 to $30 a piece. putting the weight on the front should help balance out the load more. Hope this helps.
Bill in TN
02-09-2003 13:07:15
Interesting question....The shop manual says to adjust the hydraulics with 750lbs attached to the 3 point hitch....I think the weight of the tractor is 4200lbs....but then leverage occurs.....I'll run this question by one of my college boy engineering wis kid friends and see if he can tell us..... makes me wish I'd paid more attention during math class....
