MF35 Deluxe
Andy
02-08-2003 18:21:42
I have slow or no operating hyd. when the tractor is cold in cold weather. The fluid on the dipstick for the hyd. is milky so I would say that it has water in it, but how did the water get in there and how do I keep it from happening to the new oil when I change it. What type of oil do I use in that tractor for the hyd. system it smells like 90W. Had same problem with a MF50 we change all the oil and it was good for about 6 months then back to milky. The shifter boots are ok. Do they make any types of additive for water in oil system? I think it a problem with that design of tractor. Where is the vent for that system?
Spence
02-09-2003 04:19:23
 Re: MF35 Deluxe in reply to Andy, 02-08-2003 18:21:42
I change my oil in the fall regardless. I have 2 oil changes with the same oil for 3 years on average. What I mean is I have 2, 10 gals barrels and I alternate them for about 3 years.
I drain my case then let that settle. I fill the case with the previous oil. I siphon off a barrel to about 1 1/2 inches from the bottom to leave out the sludge. I top up the case with new oil. My oil is clean and clear all the time.
You should change because of condensation buildup even if you have no leaks. 3 years is max for me but depends on usage.
Chris C.
02-08-2003 20:27:05
Andy, if your fluid is milky, you need to change it soon as the water can settle around the hyd. pump, then freeze and cause a very expensive repair. Water can enter from the shifter boots, the master control spring boot or the filler port if it doesn,t have a gasket.The vent is a little pipe with a cap just below the seat on the right side of the tranny housing. I have seen them with the cap missing.As for the fluid there is a lot of debate on fluid types for older tractors, just don't use a detergent type as it will foam and cause a jerky lift. My 35 lift is slow in cold weather also even with no water in the system, the stuff is 80 weight so I expect it to be sluggish till its been stirred up some.
