MF 35 Diesel
Chip Fontaine
02-07-2003 04:44:26
I have had a MF 35 Diesel for about 4 years and it has always run fine and started fairly well even in cold weather. Recently I change both fuel filters and cleaned the sediment bowl and intank screen. I have cleaned the screen before and changed one filter but this last time is the most extensive cleaning I,ve done.
Since this, the tractor has been harder to start and smokes when first started. I don't beleive the smoke is oil it seems to be unburned fuel. Is there a "mixture adjustment" of some kind? I am not too familiar with diesel engines and thier subtlties.
Any help would be greatly appreciated.
Chip
02-07-2003 10:37:16
 Re: MF 35 Diesel in reply to Chip Fontaine, 02-07-2003 04:44:26
If you have the Perkins diesel, and this all started after you serviced the tractor, then I would go all the way back through the fuel system, and look for air leaks. (Loose fittings / filter housings, pinched, or misaligned gaskets, etc.) The Perkins, can be a pain to get primed at times, but once it is, and the system is tight, then she should light off right away. Good luck
scotts
02-10-2003 22:03:20
 Re: Re: MF 35 Diesel in reply to Chip, 02-07-2003 10:37:16
my 35 diesel starts up fine but smokes a lot until it is warmed up thoroughly. It does leak fuel whem parked- does a fuel line leak cause it to smoke ? or are they unrelated ?>
