Mounting a lift to MF 65
Mark Stibley
02-03-2003 19:16:02
I have a gas MF 65 of which I wish to mount a lift/front end loader. I have a lift that will fit however it is not a MF lift.
My question is can I run a driveshaft through where the hand crank would be located to power the lift?
Thank you and appreciate any information,
Mark Stibley
GR
02-04-2003 19:19:52
 Re: Mounting a lift to MF 65 in reply to Mark Stibley, 02-03-2003 19:16:02
It can be done. I am rebuilding a diesel now, that used a shaft with a prong that fit into the crank nut. The better systems use a plate over the crankcase pulley with a threaded or splined shaft. The fit is close to the rear pivot shaft make sure it does not have any "play" and hit the attached plate; it is a mess.
Give me an e-mail and let me know how things are going.
GR
