Hi everyone,I tried to do my homework before asking these questions, but I just need advise. I am a pretty good automotive technician, but not a tractor expert. I have a Massey Fergurson, model MF 35, 3 cylinder Perkins diesel, SNW 237831. This is a dual clutch application with a multi-power transmission. I had a transmission/hydraulic leak and split the tractor to repair it. I found the front PTO and main shaft seals leaking. I removed every component that could leak inside the bell housing area and resealed and/or re-gasketed it. I replaced the internal and external main shaft/PTO shaft drive seals and metal sealing rings. I disassembled the control valve, which was rusted in position (I believe in the low position) and freed it up. The high/low multi-power lever was stuck (as though I thought), so I freed it up as well. I additionally replaced the front bushing in the main shaft housing. I reassembled the tractor. At that point, I was stumped and called the previous owner to ask what type of transmission/hydraulic oil to use. He stated he always had used hydraulic oil (for 10 years). Since the old oil had resembled hydraulic oil, I asked several people about the difference between the hydraulic oil and the tractor oil. I received way too many differences to explain here. I decided to put the same back in the tractor as the previous owner had no problems with the tractor. Tractor seemed fine and no leaks. The tractor was placed back in it's usual spot, which is out in the elements of mother nature. A couple of weeks later, a hurricane came close to our area and dumped severe rain. After the hurricane passed, I went to start the tractor and use it. I first checked the oils for water intrusion, but they all checked fine. I had a little trouble, as the starter had to spin out some water. I started mowing a 140 x 250 lot and noticed what appeared to be vapor from the bell housing. I figured it was water vapor because it had no oil smell. Half way through cutting the lot, a huge burst of smoke came from the bell housing. I immediately shut it off and looked below to see a stream of hydraulic oil pouring from the transmission weep hole. I split the tractor again and found several things. The PTO shaft and collar housing were blued due to heat, which was not caused by the throw-out bearing. The PTO shaft/collar housing bushing had turned in the housing, which probably caused the heat. The seal was completely breached by the bushing. Luckily, I had kept all the old parts. The old bushing still had a pressed fit to the housing. The housing was not scarred. The new bushing seemed to have had a pressed fit when it was installed, but I can't swear to it. All the parts that I had replaced were parts from the dealer. I went to the dealer, and they could not explain any better than I, as to what had happened. I bought the new parts I needed again and repaired the tractor. I asked several other persons about the type of oil issue, but no one knew the real answer. I really don' t know if the oil was the cause or the bushing was just not tight in the outer fit. I remember the bushing being a press fit and not at all tight on the main shaft. I believe the oil is pumping oil to the bushing area. The pump delivers oil to the valve, but I could not verify if the oil is going into that particular chamber when it is assembled. There is no way to test that condition. The oil did blast out causing the burst of smoke. I started investigating the oil issues and I don't have any source to verify that the oil viscosity was/is the problem. I now know the difference between the hydraulic oil and the tractor oils, but the viscosity issue of the tractor transmission/hydraulic oil is driving me up a wall. The dealer said the multi-power transmission requires (ed) 10W 20 tractor transmission/ hydraulic oil. Hydraulic oil is 10W. I do not want to split the tractor again to have the same problem. I have read the tractor forums and everybody is stating different things about the oil for the MF 35. This is a multi-power transmission; I cannot believe the 90W mineral oil is what is required. The ISO 46 that was mentioned for other MF applications also seems quite heavy. Am I wrong about this for the multi-power transmissions? I read that Big Dean is the Guru for the forums here. After reading some of his stuff, I now realize that the front seals may blow out in high, due to the leakage. (I hope that is right, high?) Although I did not see excessive wear at the metal sealing ring areas, I will lock the low position for the future. I guess that is why the lever was locked in low before I fooled with it. That still doesn't explain the blueing issue if there was too much oil pressure, unless my theory is correct about the brass bushing spinning. Maybe Big Dean could help me understand what went wrong and if it was the oil. Maybe some of you could help me understand what went wrong and if it was the oil. What is the required oil for this MF 35 multi-power transmission? Any help would be much appreciated: I don't want to do this job over again. Thanks in advance. I welcome all Information and suggestions. Sincerely, Glenn Hartline
