Crack in block
G Cole
01-28-2003 17:15:15
I have a 165 that has been welded on the block. No water gets in the oli, just a little seeps out on the side. Could I use jb weld to fix that? Whats your suggestion?
G Cole
01-29-2003 12:42:17
 Re: crack in block in reply to G Cole, 01-28-2003 17:15:15
Thanks for the info Rod and Farmman
kjm
01-29-2003 16:59:09
 Re: Re: crack in block in reply to G Cole, 01-29-2003 12:42:17
Just add ginger to the radiator as stop leak , this should fix it and won`t plug the rad.
gcole
02-01-2003 16:26:32
 Re: Re: Re: crack in block in reply to kjm, 01-29-2003 16:59:09
KJM, are you saying add ginger only? Not any stop leak? How much? Thanks
Bob
01-30-2003 03:44:10
If Ginger don't work, try Mary Anne.
Farmman
01-29-2003 07:41:02
Know guys who have done it. Like Rod said get the area super clean and no liquid around area to be patched. I use laquer thinner to clean stuff up good. Takes everything off.
rod
01-29-2003 05:03:03
I fixed my tractor that way you have to grind area clean and drain all water out also if you can park it on a side hill so any coolant will not seep out of the crack if will work area must be super clean I used brake cleaner to get it clean after I ground it off with a small dremel rotary tool.
regards
rod
