Massy 33 vs. Farmall M
John
01-26-2003 10:25:25
We have A massey harris 33 rowcrop. The tractor seems to have quite a bit of power. It seems like there is much less info. on the 33 than the 44. Why is this? The only difference i can find is that the 44 has a bit more power. Would An M farmall be a good comparison to the 33, or what will pull more? An M is a 3 plow tractor but i've seen the 33 rated as a 3 plow to? Any info on the 33 would be greatly appreciated..
David B
01-26-2003 20:46:33
 Re: Massy 33 vs. Farmall M in reply to John, 01-26-2003 10:25:25
I always considered an "M" and a 44 were pretty equal on horses and work. The 33 is a good tractor just a few cubic inches shorter and 5-6 horses less than a 44 and maybe 10 horses less than a 44 special which produced about the same years.
Farmall Daddy/// you want info, this should help you out
01-26-2003 17:11:49
Years Produced....1952-1954
#'s produced..... 8,781
cylinders..... ...4
bore and stroke...3.625 X 4.875
RPM's..... ..... .1400
Cubic Iches..... .201
gas tank..... ....19 gallon cap.
PTO Horsepower....39
Drawbar..... .....35
1st..... ..... ...2.75mph
2nd..... ..... ...3.8mph
3rd..... ..... ...4.8mph
4th..... ..... ...6.7mph
5th..... ..... ...13.5mph
reverse..... .....3mph
Bruce Colbourne
01-26-2003 16:55:00
John if you could give me your e-mail I could send you all the specs I have on the model 33.The 44 and the 33 are very different to each other.
ray-s
01-26-2003 13:57:23
Link
this site has specs on the 33 and other masseys.
Jason
01-26-2003 12:23:53
Belt Horsepower: 35
Bore and stroke: 3.625 X 4.875
Compression Ratio: 6.3 to 1
Cubic Inch: 201
I have a book on the 33 with alot more info. Not 100% sure on the horse power rating. Seems like it should be less.
The Farmall M has 248 cubic inch with a bore and stroke of 3.875 X 5.25 and a belt horse power of 36.
My neighbor has a Massy 30 and I have a Farmall M. When working together I would prefer the M,and Im not saying that just because it is mine. They are both good tractors though.
If you would like more info just let me know. Hope this helps!
J.D.
01-29-2003 22:46:18
 Re: Re: Massy 33 vs. Farmall M in reply to Jason, 01-26-2003 12:23:53
We had a M and a 44 in sandy loam soil conditons. The M was a good 3 plow tractor, and the 44 was a good 4 plow tractor.
Farmall Daddy
01-26-2003 17:14:43
I have a book like Jason's but I don't know if he has just a Massey book, I have got the Nebraska Test Book{not trying to brag about it}.
