FRONT END LOADER FOR A MF 235
JEFF PETERS
01-23-2003 13:25:38
IS THERE ANY MANUFACTURER THAT MAKES A FRONT END LOADER FOR A MASSEY 235. THEY SEEM TO MAKE ONE FOR 245'S 471'S ETC BUT NOT THE 235. THE DEALER SAYS THAT THE 232 LOADER WILL NOT WORK. I'VE ALSO TRIED BUSH HOG AND THEY DO NOT HAVE AN APPLICATION FOR A "235". THEY HAVE EVERYTHING BUT. PLEASE HELP. THANK YOU.
Don-WI
01-26-2003 08:40:03
 Re: FRONT END LOADER FOR A MF 235 in reply to JEFF PETERS, 01-23-2003 13:25:38
Also do a search for westendorf manufacturing. They make a few different loaders with brackets to fit almost anything.
Don
Bus Driver
01-24-2003 13:28:39
Dunham -Lehr makes loaders that fit most every tractor. Just have to get the mounting brackets for your particular machine.
Will Luft
01-23-2003 19:23:15
I have an Agco "Farmhand" on my 235. Fits like a glove and works like a mule!! Quick detach also, two bolts and two hydraulic quick couplers and it's off, but not usually for long. Check with Agco.
JEFF PETERS
01-24-2003 06:57:33
 Re: Re: FRONT END LOADER FOR A MF 235 in reply to Will Luft, 01-23-2003 19:23:15
WILL..WHAT IS THE BRAND AND MODEL NUMBER OF YOUR LOADER? JEFF
CH
01-23-2003 15:15:18
I don't know the size of a 235, but the mounting instructions for my 1020 Woods says the mounts fit the 135-253 models. This loaders on my 245.
JEFF PETERS
01-23-2003 18:19:23
 Re: Re: FRONT END LOADER FOR A MF 235 in reply to CH, 01-23-2003 15:15:18
IS THERE A WEBSITE WHERE I CAN FIND OUT MORE IMFORMATION ON A WOODS 1020 LOADER? THANKS
Gary F
01-23-2003 19:15:38
 Re: Re: Re: FRONT END LOADER FOR A MF 235 in reply to JEFF PETERS, 01-23-2003 18:19:23
Link
Try here and look under Allied these guys are the Mfgs.
Good Luck
Gary
CH
01-23-2003 18:42:45
Link
Look under agricultural products.
Good luck. Charlie
