MF50
Frank
01-20-2003 20:31:18
I just bought a MF50 that had recently got a new clutch, the pedal seems very hard to push, I have to stand to push it down. Does Any one have any Idea's how to solve this problem ?
Scott from Pa.
01-22-2003 12:20:37
 Re: MF50 in reply to Frank, 01-20-2003 20:31:18
Frank, Makw sure your two stage clutch is adjusted properly. I had trouble with mine because the second stage for the PTO was engaging as the tractor was starting to move. It made it a real bear to push down the clutch. There should be app. .090 space between the secondary clutch fingers and the main clutch. See if that will help. It made a world of difference on mine 50.
Frank
01-22-2003 13:05:33
 Re: Re: MF50 in reply to Scott from Pa., 01-22-2003 12:20:37
Thanks for the responce Scott. I will check it out. Frank
