Power Steering on the MF202
Dave_D
01-20-2003 15:35:17
I was using my bothers MF202 and man is it hard to steer. I added fluid to the pump and realized it had a bad hydrolic line. Replace the line and it was only a tad easer to steer. Did notice a small leak at the top of the steering column. Does the column part work just as a valve?
Any idea, sure would make life easer if the PS worked.
Thanks
- Dave
Jack
01-21-2003 06:20:30
 Re: Power Steering on the MF202 in reply to Dave_D, 01-20-2003 15:35:17
Where did you find the pump location to add fluid? I cannot find mine.
I think under the tank by the steering wheel there is a filter block that the lines seem to go through,maybe it is plugged up.
jack
Dave_D
01-22-2003 08:49:03
 Re: Re: Power Steering on the MF202 in reply to Jack, 01-21-2003 06:20:30
I just followed the PS lines to the pump. The pump is on the front left of the engine. It had a square headed plug where you add the fluid. Looks like I need to get a manual for the 202.
Thanks
Jack
01-21-2003 06:22:06
Also in the manual it says it uses type a tranny fluid. Maybe thats the problem fluid in there to thick?
iowadave
01-25-2003 18:40:13
 Re: Re: Re: Power Steering on the MF202 in reply to Jack, 01-21-2003 06:22:06
Must be some differences in pumps depending on what year 202-mine's on the side of the engine, up near the front, opposite the oil fill. Manual sez you take the top of the resevoir and fill to the full line.
3FJACK
03-22-2003 18:24:51
 Re: Re: Re: Re: Power Steering on the MF202 in reply to iowadave, 01-25-2003 18:40:13
Make sure u are not using tranny oil insted of type A automatic trans oil !!!!! GOOD LUCK
