MH 33 Piston assembly
PREGIER
01-20-2003 08:05:43
I have a MH 33 engine that I bought dissembled.
I put new rings and rod bearings on and Im ready to put it back in the block, My question is the on one side of the piston is a slot cut in the shape of a "T" which way is that slot face the camshaft side or the right hand side of the engine(when sitting on the tractor) The manual shows me which way the rod faces put does not mention the piston orientation. any help would be appreciated.
ET
01-20-2003 16:48:41
 Re: MH 33 Piston assembly in reply to PREGIER, 01-20-2003 08:05:43
The rule of thumb is the numbers on the rods face the camshaft. The solid side of the piston is the thrust side of the piston on the downward power stroke, the slot is for lubrication. I hope this helps.
PREGIER
01-21-2003 06:50:01
 Re: Re: MH 33 Piston assembly in reply to ET, 01-20-2003 16:48:41
So the slot in the piston will face the camshaft?
(Thanks for the help)
