MH 50 WEAK LIFT
JON
01-18-2003 16:15:36
HAVE 1957 MASSEY 50 THE LIFT WORKS FINE BUT WILL NOT PICK UP MUCH WEIGHT.HAVE CHECKED FLUID AND IS NO LEAKS .THIS TRACTOR HAD THE PROBLEM WHEN I GOT IT .HAVE BEEN TOLD THIS IS A COMMON PROBLEM WITH FERGUSON TRACTORS.
paul
01-19-2003 03:30:02
 Re: MH 50 WEAK LIFT in reply to JON, 01-18-2003 16:15:36
check the filter. do the lift arms "bob" up & down? if so your control valve is leaking. if it has the right oil & a clean filter, it can only be control valves or the pump itself. good luck
