Massey 1100 questions
Corey Dawes
01-15-2003 12:41:41
I am thinking about buying an 1100 MF. Its diesel and the motor has been rebuilt but it has a noise in forward gears, but not in reverse. Could it be a bearing in the trans? How hard are these trans to work on? and what would be the approximate value of this tractor considering that it may need some work? any info would be appreciated.
Charlie
01-24-2003 18:35:22
 Re: Massey 1100 questions in reply to Corey Dawes, 01-15-2003 12:41:41
Did you buy this one? If not where do you live(state)? I need one for spares.
CH
01-19-2003 06:04:04
Just under 6 ton.
Merle
01-18-2003 14:26:16
Corey
Sounds expencive if you don't have a parts tractor avalable. If you can, drop the hyd filter under the transmission. What you find (ie. metal filings, flakes, bearing pieces) will give you a good indication as to what is wrong.
Merle
kjm
01-18-2003 06:44:49
Run away from this one,MF uses the same oil in the tranny,rear end and HYD. If it has started to grind a bearing up in the tranny it can destroy the hyd system. If you can get it very cheap you might take a chance.
Corey
01-18-2003 08:41:41
 Re: Re: Massey 1100 questions in reply to kjm, 01-18-2003 06:44:49
Thank you for your response, it might save a lot of headaches. The man wants 1200 dollars for this tractor, what would be cheap? about 500 be worth the gamble?
