44 sleeves
JDBert
01-15-2003 06:57:55
will the sleeves of a H277 fit in a H260 and is it possible to bore them to 4 1/16 for M&W pistons
Don L.
01-16-2003 11:30:27
 Re: 44 sleeves in reply to JDBert, 01-15-2003 06:57:55
H260 sleeves and H277 sleeves are not the same, the pistons are. I can provide [ in time ]a good used sleeve bored and fitted to a 4 1/16 M@W piston with a new O ring.
Don L.
Rusty Acre
Austin MN.
ph 507 433 0073 am best
JDBert
01-16-2003 06:32:31
I've got a H 260 with a M&W 4 1/16 over bore kit in it already, Only problem is that in tearing the motor down for a rebuild one of the sleeves broke. So thats why I was wondering if it is possible to bore a stock sleeve to 4 1/16 or if I have to find another M&W sleeve.
bruce colbourne
01-15-2003 20:01:22
The H260 and H277 are the same block.The size of the pistons are different.You can buy the 4-1/16 piston and linner kits to fit these engines.I found them on the net just can't remember which site it was.Will do some looking and get back to you.
Jeff
01-16-2003 15:26:01
 Re: Re: 44 sleeves in reply to bruce colbourne, 01-15-2003 20:01:22
Bruce,
If you have a place to buy pistons & sleeves, that actually has them in stock, please let me know. I betting they may list them, but probably don't have them available.
Thanks
Jeff
Jeff
01-15-2003 19:50:34
Actually, I don't think they will fit. I will double check & get back to you.
Jeff
marlowe
01-15-2003 10:33:14
same block so they will
