Ignition wiring
MF 135
David S.
01-14-2003 11:02:55
I'm helping a friend rewire his MF 135 with the Continental Z145 gas engine. I don't see a ballast resistor anywhere on the schematic or in the parts book. Did this tractor not use one, or is the wire to the coil a resistance wire? The schematic doesn't indicate such, but I thought I should check with the "gurus".
Thanks in advance for the help.
David
Big Dean
01-14-2003 13:13:36
 Re: Ignition wiring - MF 135 in reply to David S., 01-14-2003 11:02:55
The MF135 did not use either a ballast resistor or a resistor wire
David S.
01-14-2003 14:35:38
 Re: Re: Ignition wiring - MF 135 in reply to Big Dean, 01-14-2003 13:13:36
Thanks Dean,
Well that makes wiring the ignition a lot simplier, only how did the factory prevent premature point burning? Does the coil have resistance built in that lowers the voltage to the points?
Thanks,
David
