575 noise, now will not start
Karl R
01-14-2003 03:33:05
I bought a MF575 recently, which ran nicely apart from the need for an occasional fuel system bleed.
Last week after it had been stood in the cold (about 5 below) it started unevenly and had no power at all. The engine note was uneven and it had a noticeable clanking/hammering when under load.
Now, a few days later, it will not start at all. The diesel is getting to the injectors ok, I've changed the diesel and the filter, oil and the filter since. None of the electrics work at present, so I've no idea if it's getting oil. I've taken off the rocker cover and all the valves seem to be operating normally. The engine turns over normally on the starter. If I use a can of spray starter it will run for a few seconds and then stop.
I hoped that it might be back to normal today with it being much warmer, but no change. Any suggestions appreciated? I'ma bit of a novice with diesel engines! Many thanks!
Make mine a Massey!
01-16-2003 17:30:35
 Re: 575 noise, now will not start in reply to Karl R, 01-14-2003 03:33:05
1--- Check your engine oil----is it up or thin
2---- If it is remove your fuel pump and replace all the check valves and the diaphragm , they will leak if too old , make you replace check valves properly , one each way This will cause it to loose prime on the fuel system and require occasional bleeding . Once it gets too bad , not enough fuel gets to injector pump to run engine . Worked wonders on my old Masseys---Bill
Fred Kobs
01-14-2003 19:37:08
I'm thinking that I would check compression before spending money on pump rebuild. might have to build yourself an adapter and borrow a hi-press. guage to do it though. Then have injectors tested while they are out. A weak diesel is Very temporamental when it comes to ambiant temp. Got a block heater on it? I used to get weak Isuzu diesels running by squirting oil down the air intake to make compression but I DO NOT reccomend it.
dick
01-14-2003 09:50:28
If it runs with the spray starter the problem is probably that it's not getting any fuel. If fuel related, the clanking/hammering is probably caused by a blocked injector. The engine will run (although roughly) with one injector out of the game so chances are that more than one injector is blocked.
The reason could also be improper bleeding of the fuel system. The diesel engine is quite sensitive to air in the fuel system.
The usage of any kind of starting fluid is not recommended. It can damage the engine.
Karl R
01-19-2003 09:37:23
 Re: Re: 575 noise, now will not start in reply to dick, 01-14-2003 09:50:28
Well - the problem is solved and amazingly it was completely unrelated!
I gave up on it for a little while and went on to do some electrics, at which point I discovered that the wires to the heater (glow) plugs were broken. I replaced them and the engine started just as well as ever.
I can understand how this might have stopped it starting, but how it would cause it to run on only some of the cylinders I don't know!
In any case, all is fine now. Thanks to everyone for your help! :)
Karl R
01-17-2003 08:22:07
I've now had another look. There seems plenty of fuel going to the injectors - if I loosen the locknut on the gland, it squirts out of the gap vigorously in time with the normal engine sequence.
However, NONE is getting to the engine. I've had the injectors out and they look normal, but when I refitted them "upside down" and turned the engine over, no diesel was visible from the jets and when I wrapped a bit of paper over the jet and did the same the paper stayed dry.
So...the injectors not injecting at all? Does this sound like a pump problem?
Karl R
01-14-2003 11:20:40
Thanks Dick,
That's very helpful. It did occur to me today that the spray was probably just working as a substitute fuel because as soon as I stopped spraying, the engine stopped. I don't have any plans to use it long term - I have heard that it causes damage, but just wanted to see if it was just the cold (which it wasn't).
I'll try taking the injectors out at the weekend and (from a safe distance) see if they are all spraying normally or if one or two are failing and need replacing.
I guess that if none of them work then it's probably a problem with the injection pump; if they all work then perhaps the injection timing...?
Is there anything else that I can try that might cure or diagnose the problem?
