M F 25 hyd
Ken
01-09-2003 07:19:15
I would like to corspond with some one that had worked on the control valve of the hyd .of a 25 MF I have a manual I can understand the way it works except the main control valve in the manual it shows aux valve main valve & a pic of regulating valve assy Is that a floating valve in side of the main valve? I will be removing the cover!It works as if a valve is sticking when you leave it set for a while filter been change & oil Aux & main valve free This must be a good tractor as i cant find anthing on the net . Thanks for any help
oldgoat
01-10-2003 16:39:08
 Re: M F 25 hyd in reply to Ken , 01-09-2003 07:19:15
I found out that valve assy is to control the the speed the hyd will drop when you shift the lever left hand side of the seat Thanks ken
