Rear Work Light
Wayne in Tn.
01-06-2003 19:50:14
I have a '66 MF135 that doesn't have the original style rear work light. Is it true that the originals can be toggled from red to regular work light?Are these still available from Massey or some other vendor? It didn't bother me until I started looking at other pictures of my model and noticed it! Thanks to all.
geb
01-08-2003 06:34:30
 Re: Rear Work Light in reply to Wayne in Tn., 01-06-2003 19:50:14
I have one off a Massey 33 that is in good shape except for switch. Both lights burn. $40 plus shipping.
Wayne in TN.
01-12-2003 15:17:13
 Re: Re: Rear Work Light in reply to geb, 01-08-2003 06:34:30
Hey Geb have you still got the light?
Clark Cotten
01-07-2003 14:33:35
I recently bought one from Willy-N. The work light is a sealed beam unit with a transparent red coating applied to the rear of the sealed beam unit. Another separate small lamp is mounted behind the sealed beam and when it is turned on it gives a red colored light. The work light is off when this smaller bulb is on. There is also a flasher unit inside the work light can.
I don't know if these are available through the dealer or an aftermarket source.
Willy-N
01-10-2003 22:02:53
 Re: Re: Rear Work Light in reply to Clark Cotten, 01-07-2003 14:33:35
I still have the other light and it is on my Massey 135 tractor. They were the original ones that came with it. You could use them as work lights, turn signals or running lights. I use mine all the time when dark and use the red when on the road and work light for plowing snow in the dark. Nice having it all in the same light. Mark H.
Wayne in TN
01-07-2003 15:58:09
Thanks Clark for your response.This tells me much more than I knew about it!
