Super 90 / 410 D Swap
Massey Matt
01-06-2003 18:09:10
Was just wondering if I can put a A4-300 Perkins out of a 410 Massey Diesel combine into a Super 90. It's the same engine but are the mounts on the block the same or should I haul the old 410 to the junk yard. It has a good engine and I would like to use it if possible.
Tom
01-07-2003 12:58:28
 Re: Super 90 / 410 D Swap in reply to Massey Matt, 01-06-2003 18:09:10
Matt
The engine blocks are the same, you would need to use the pan from the Super 90. There are some other differences depending on the serial numbers of both the combine and the tractor.
Tom Dold
Dold Implement Co.
Howard, SD. 57349
605-772-4541
