Electrical-1085MF
Mikey
01-05-2003 13:32:15
Hi. have a problem with electrical system on my 1085....everything is fine , except..the dome light-blower- and wiper....I have power to the switches,etc...until I turn either the wiper,light or blower switch on, then no voltage...any suggestions?....thanks ( this is in the cab)...
Kraig
05-13-2003 18:55:16
 Re: Electrical-1085MF in reply to Mikey, 01-05-2003 13:32:15
Run a jumper cable from the ground on battery to the structure of the cab, make sure there is bear metal where you connect it. Then try.
Tom
01-07-2003 12:33:51
Mikey
Check the cab ground.
Tom Dold
Dold implement Co.
Howard, SD. 57349
605-772-4541
CH
01-05-2003 13:36:29
If all of these components share the same fuse, the fuse may be resistive or intermittent.
Mikey
01-07-2003 13:10:06
 Re: Re: Electrical-1085MF in reply to CH, 01-05-2003 13:36:29
Thanks to all....for your help...found the problem at the connector for the cab..... the 10 guage wire was hanging on by one strand...connector was cruddy....so I bypassed the connector and straight lined the two wires for the cab...wiper and blower work now....so thanks abunch..... .
