MH Pony final drive
john wilson
12-28-2002 13:10:17
We are overhauling a MH Pony and have opened up the final drive. Pinion( the small gear) has a lot of play on the drive shaft that runs to the differential. Both sides of the tractor have the same amount of play. We can rotate the large gear about one tooth's worth of rotation. The mesh between the big gear and the pinion is pretty good( very little play). The play is between the splined shaft and the Pinion. Is this play normal and if not what parts are available to tighten it up.
Regards,
John Wilson
