Lift arm, stud-nut torque
d3Mike
12-27-2002 22:05:15
Hi, I have a 1964 MF 205 Ind. with a cat 1, 3 point. Does anyone know the torque on the large nut that holds the lift-pull arms to there mounting studs at the bottom of the pumpkin-diff housing? It seems to be the same setup as on a 35 and many other Masseys I have seen with a cat 1, 3 point. Thank You, Mike
rod
12-29-2002 05:07:30
 Re: lift arm, stud-nut torque in reply to d3Mike, 12-27-2002 22:05:15
Om my Ferguson 20 there was a castellated nut on the inside I think the torque was 150 ft lbs
regards
rod
