Massy 44
dieselram
12-26-2002 20:02:09
I was wanting some info on how much hp & how much a 44 weights with a wide front.
Thanks
matt
01-06-2003 17:08:18
 Re: massy 44 in reply to dieselram, 12-26-2002 20:02:09
I pull with a 44 with no fenders and 18.4-34 tires with pressed steel centers and it weighs about 4200 without me. the cast rear centers add about 1000 and I bet the wide front would add about 200 lbs or so. A good 44 has about 44 to 47 for hp. overall, a very light powerfull tractor. brings home alot of trophys.
Lynch
01-05-2003 01:27:07
I have an original 44 diesel parts book from MH if you need it. Lynch
David B
12-26-2002 20:28:11
1947 44 gas tractor Nebraska test tested at 45.6 belt horsepower and 39.9 draw bar horses. The row crop tricycle weighs 4165 lbs, std tractor weighs 4485. If you have a row crop with a wide front it probably weighs near the standard listed weight. Also I am sure this would be without cast wheels that they used on the later 44's.
