Loader hydraulics
Dennis
03-01-1999 10:04:51
I am thinking about replacing the single ram on my TO-30 Wagner lift with 2 rams. This will equalize the load on the bucket and make for smoother action, reducing twisting of the bucket.
A Question to you hydraulic engineers - I know that the combined fluid capacity of the new rams will have to equal the capacity of the original single ram so as not to outsize the pump but will the fact that they are both 1/2 the size of the original reduce the physical load capabilities of the bucket???
I don't know if two smaller rams equal the same power as one twice the size ram.
Anyone know ?? Thanks in advance.
steve
03-02-1999 07:23:49
 Re: loader hydraulics in reply to Dennis, 03-01-1999 10:04:51
You had the answer to your question right there. To get two cylinders with the same "power" as one cylinder, they must each be larger than half the diameter of the single. That is because cylinders are round, and the area of a circle is pii times the radius squared.
You would almost need two three-inch cylinders to replace a four-inch cylinder.
