MF35 PTO Shaft Installation
ScottS
12-23-2002 10:56:51
Question: I have removed the PTO shaft from my MF35 Diesel to replace the bearing and seal. As I follow the manual, everything seemed to make sense, except for this last, cryptic comment: If the hydraulic pump is installed, loosen the dowels and install the end of the pto shaft into the needle bearing.
Not sure what this means but it sounds like I just can't stick the shaft back in ? the inboard end of the shaft seems to ride in the hydraulic pump. I am not sure what they mean by loosening dowels ?
anybody been there, done that ?
What is the procedure for reinstalling the shaft.
By the way, the bearing I took out said Made in England- how long were replacement parts english and how old do you think that bearing may be ? Maybe it is original ?
Gary Reynolds
12-23-2002 14:31:21
 Re: MF35 PTO Shaft Installation in reply to ScottS, 12-23-2002 10:56:51
On either side of the rear case there are two pins that align the hydraullic pump in the housing.
Gary
