1150 Massey pros/cons loader?
Reaver
12-22-2002 20:04:16
What reputation does the 1150 Massey Ferguson have?
Good points / bad points?
Anything to be concerned about engine? transmission?
How would one handle a loader?
Appreciate your comments.
Reaver
John
12-28-2002 08:05:28
 Re: 1150 Massey pros/cons loader? in reply to Reaver, 12-22-2002 20:04:16
You had better price a rebuild kit for that 510 V8. Then price one for any 354 Perkins. V8's are very expensive to fix, compared to 6 cyl engines. I know because I own an 1100, 1130 and 1150 plus two 3000 series. I would choose a Massey 246 loader if I was to put one on an 1150.
ted
12-27-2002 18:17:25
The 1150 is a good solid machine. We have one still going strong. Good hyd. I think it would make a good loader tractor if you wanted to put a loader on it.
Bob
12-24-2002 10:02:15
The 1150 is rates at 135PTO HP. The 510 V8 is a nice smooth running engine. Lots of power. Naturally asperated but I have seen some with M&W turbo kits. I have one right now that I am restoring . Had another one before that I really liked a lot. No cab on either one.
Merle
12-23-2002 21:21:59
Don't know much about the 1150 but the 1130 makes an awesome loader tractor, Everythings the same except the motor is bigger.
Reaver
12-24-2002 07:46:25
 Re: Re: 1150 Massey pros/cons loader? in reply to Merle, 12-23-2002 21:21:59
What kind of loader do you use on it?
Approx how many horsepower are we talking about?
Can you still find new / used loaders that fit well?
Reaver
Merle
12-26-2002 20:13:46
 Re: Re: Re: 1150 Massey pros/cons loader? in reply to Reaver, 12-24-2002 07:46:25
My brother has a Westendorf WL-40 on his 1130, it is rated at around 120hp. A Westendorf WL-40 and WL-42 are both the same with the 42 having a Quick attach bucket. Both should fit on your 1150. The Massey 1100/1105, 1130/1135, and 1150/1155 all use the same components from the clutch back with only the engines and sheetmetal being different. If the 1150 you are looking at has high hours I would look it over real carefull. One good test is to work the tractor for a couple of hours shut it off and pull the hyd oil dipstick,if the oil on the dipstick glitters in sunlight the rearend needs attention. I had a 1155 and it was a good tractor but the 1130 would always be right behind the 1155 pulling the same load and using a gallon of fuel an hour less. If you have any more questions feel free to email me.
