Where to find stabilizer bars
Paul
12-20-2002 00:24:16
My neighbor has bought a MF that needs stablizer bars for the 3pt.hitch. I think the tractor is a 285. Where can we find those parts? Thank you. Paul
Brad Lewis
12-25-2002 18:41:31
 Re: Where to find stabilizer bars in reply to Paul, 12-20-2002 00:24:16
The best that I have used came from Tractor Supply. They have a threaded end at each end so they be used to adjust the location of the implement. Merry x-mas from Lexington, TN.
Robert in Md.
12-20-2002 17:29:56
I have one MF bar and made the other bar from bar stock. The bar stock one has bent several times. I've stopped using it , Just use the factory one without any problems.
C. T. in Oklahoma
12-20-2002 16:15:57
I found them at Tractor Supply Co.
C. T.
Randy
12-20-2002 01:06:52
I bought mine at the MF dealer.
Paul
12-20-2002 01:16:18
 Re: Re: Where to find stabilizer bars in reply to Randy, 12-20-2002 01:06:52
That's what I told him to do. He claims they don't have them anymore.
TenMiles High
12-20-2002 10:05:07
 Re: Re: Re: Where to find stabilizer bars in reply to Paul, 12-20-2002 01:16:18
Aren't stabilizer bars just pieces of 1/4-3/8" x 1-1/2" x 'however long' steel with a hole drilled in each end that keeps the implement from swaying side-to-side? Could you measure the distance from the pins on the implement to the pivots on the tractor, buy the bar stock and drill the 4 holes? (May need to hammer a slight bend on the ends to get the angle right).
