Power steering hydraulic motor
Jeff Christmas
12-19-2002 20:39:02
I need help I had a leak on this pump took it out
the other day. then when I took it apart to replace the seals in the upper end, the center shaft came out. I didn't know it had to be timed and just put it back together and you know it didn't work. And I would appreciate any help diagrams whatever to get this back together. This pump is on a 275 MF DSL.
Tom
12-30-2002 09:35:05
 Re: power steering hydraulic motor in reply to Jeff Christmas, 12-19-2002 20:39:02
Jeff
The G rotor hand pump in the bottom of of the unit must be timed to the the spool. The link shaft has a slot on the top end that fits into a pin on the spool. The bottom end of this shaft is spleend and will fit into the star gear in several diferent ways. The groove in the top has to be aligned with the valley in the star gear. There are several possibilities 1/2 of which are right and 1/2 of which are wrong. If the pin is aligned with the valleys on the star gear it will work fine.
Tom Dold
Dold Implement Co.
Howard, SD 57349
605-772-4541
