Massey Pony Valve setting
Layton Ness
12-18-2002 13:19:46
In the It repair manual it says to adjust the valve of #4 cylinder when # 1 is tdc on compression stroke but anyone who has rebuilt many engines say to adjust the valve for # 1 when it is tdc on compression stroke. However if I do this the setting would have to be differant than the .012" that the book states. I adjusted the valve the way the book says. But if you check them the normal way the clearance is about .025" would this not make the valves awful loud.
Ken in Iowa
12-19-2002 12:20:47
 Re: Massey Pony Valve setting in reply to Layton Ness, 12-18-2002 13:19:46
Layton, I didn't check my book, but know from 50 years of tinkering that you should set the clearance in the normal way. You can even turn the engine so the intake valve is full open, then set the exhaust clearance on that cylinder then turn until the exhaust is full open then adjust the intake. These Ponys are not the space shuttle.
Good Luck, Ken
Gary McClintock
01-06-2003 20:04:49
 Re: Re: Massey Pony Valve setting in reply to Ken in Iowa, 12-19-2002 12:20:47
Do you know what a 1951 Massey Harris Pony is worth? This one has the orginal paint and tires, it runs good has a PTO and adjustable front axle with three implements: 1 bottom 16in.plow,6 ft.sickle mower and frontend snow blade all in good working condition. Serial # PGA15168 Limited Toronto,Canada. Always has been shedded. I'm trying to get some idea on how to price this tractor as my Dad is 81yrs.old and is thinking it's time for him to slow down alittle. He has either mowed or plowed with this tractor every year since 1964. It's never missed a beat. Any help on this matter would be most appreciated. Thanks, Gary, Sterling,KS
