MH-50 carberator
donald shannon
12-09-2002 17:42:31
I have above tractor.
It has a carter UT carberator on it. I've been told it's not "original" but I need to rebuild it. So, Does anyone know what the carb "might" be from????
the only other numbers on the carb are:
0-1145 on the bowl (lower body) and 0-1146 on the throat (upper body).
Basically, it is a single barrel updraft carb.
I could really use some help in identifying what this came from so I can get the right rebuild parts for it.
Thanks for your input.
des :)
Paul in NM
12-11-2002 04:53:56
 Re: MH-50 carberator in reply to donald shannon, 12-09-2002 17:42:31
The Carter UT-2612S was an original carburetor for the M-F 50. Rebuild kits are still available.
Paul in NM
12-11-2002 05:01:36
 Re: Re: MH-50 carberator in reply to Paul in NM, 12-11-2002 04:53:56
I failed to mention that the Carter UT -2418S was used prior to SN 514381.
