Mf 150 draft control
mark
12-05-2002 16:59:41
i need to know what may be my problem with the draft control on my 150. the lift works real good but the draft goes full up or down with no in between. if it matters the rear pto shaft seal leaks and has been replaced twice, it has no up and down movement and the bearing rolls smooth.are there adjustments or do i need to overhaul the draft cylinder???
Lynch
12-22-2002 18:13:52
 Re: mf 150 draft control in reply to mark, 12-05-2002 16:59:41
The only thing I can help you with is I have a Mint condition MF150 operator's manual for sale in the photo classifieds on 12/8. I can let you have it for a bit less if you need it. I have a 175. Lynch
